Anti Lock Brake sound | Ford Explorer Forums
troyboy
Chesterfield, Mi
1995 Sport
When i make my first stop of each day in my subdivision and it sounds like my anti-lock brake comes on on my front passenger side. I have a 95 Explorer Sport, does anyone have any idea if its just a sensor going bad or what it could be?
I had the same thing on my 97. i pulled the ABS fuse until I was able to replace the sensor. It stopped kicking off after fuse was pulled. just make sure you remember to put it back in when you put new sensor on.
thank you so much for that
My driver's side is starting to act up; I think it is from a build up of grease due to a failing wheel bearing. I cleaned the sensor and there were no problems for about 75 miles then it started acting up occasionally again. You many want to make sure it's not just dirty before you put the new one on.
