Anti theft light | Ford Explorer Forums
Anti theft light
cjs04eddie
stafford va
2004 ford explorer
I have 2004 ford explorer 4.6l and i have a really weird problem where when i turn the key to on the anti theft light begins to flash rapidly, and if you go under the hood you can hear a clicking noise coming from the throttle body, if i quickly disconnect the throttle body and reconnect it then it allows me to start the vehicle and i have to do that every time i want to start it, now if i jump another running car up to it so that it has 14v when i turn the key the light wont flash at all and it starts right up. Let me give some backstory, The voltage regulator in the alternator went out and sent of 18v through the system, i replaced the alternator and the pcm and had the keys programmed. Id like to add that ive already tried replacing the throttle body and the pcm is already been replaced like i said before, does anyone have any idea?
What is the voltage at rest, and while cranking when are not jumping it with another vehicle?
