Antifreeze in Vacuum line?? | Ford Explorer Forums
TerryAlanCoen1
I need help - My wife's 2002 sport-trac has been hard to start after the first start of the day. It starts OK in the morning or after it has set a long time, but if you try to start it soon after the first start you must hold your foot to the floor and you get a rough idle and black smoke for a while. I suspected a leaky injector and started to dissasemble it. When I removed the vacuum line that goes in reight behind the throttle body, I noticed that antifreeze leaked out of it and it looks like the intake may be sucking antifreeze from that vac line. Does that make sense? Any help woul be appreciated. Thanks!
Edit Report
..No need in creating multiple threads in the hopes of getting a quicker response..
..While you are waiting you can more than likely find your answer by using our 24/7 search function..;)
..This thread I am linking here will help with your searching of your answers while you are waiting for others to respond to this thread..:biggthump
http://www.explorerforum.com/forums/showthread.php?t=245056
Thanks
Hello - sorry - every time I hit send I got an error. It didn't look like the thread was being posted. Thanks for you help.
