Any way to get previous "key'd" marks off? | Ford Explorer Forums
dreddog47
NJ
96 Bronco/04 Marauder
the 94 we bough has been w/o a doubt keyed before, although it isnt through the paint to the bare metal. Its just white lines (rather faded ones to, you cant really see em in pics)
How hard would it be to remove all the white marks? While the truck is a beater theres no reason not to try and make it look abit better :thumbsup:
ill get some pics of the overall damage so i know what can be buffed out and what cant be.
If you can run across it with your finger nail, try wet sanding the clear coat.
what Blee means to say.
If it catches your fingernail then repaint is the best solution.
If it doesnt catch than it could be buffed out.
That doesnt nessicarrily mean WET sanded. It could be dry sanded and buffed as well.
Surface scratches in the clearcoat only can often be filled and look like new after using 2-3 coats of a good wax.
