A91EBexplorer4x4
- February 15, 2000
- Memphis Tn
- 1991 EB Explorer 4x4
lets see i have bought the superlift 5.5" lift with extended radius arms and SOA. i have only had it on for about a month or maybe two so far i have broken both axle perches bent both front sway bar mounts. from breaking the axle perches it caused the axle wrap wich in turn broke my drive shaft yoke, u-joint and i believe it has messed up the pinion gear ( lots of slop in the pinion gear now and i can't remove the yoke from the flange to get to the pinione bolt, could be it busted the bearings in it) the only thing i think that is going to hang in there is the extended radius arms. they seem pretty strong. i have yet to get rid offthe sway and it doesnt seem to want to be aligned good. just over all im not to happy. im in the process of talking to superlift about the broken axle perches wich caused other broken parts. i know there are a few other people that have had these problems so let me know it might just give me a lil more back up.
Thanks,
Howard
Thanks,
Howard
