Thanks guys. JW, that appears it will be especially helpful.
pwrshft99, There is nothing conclusive telling me its a head gasket. I have been using coolant in the vehicle for some time now and it has gotten progressively worse to the point where I now have it parked, although I did drive it today 40 miles and will check it this afternoon to see how much if any was used again.
We've done leakdown tests, compression checks, pressure system checks.
Pressurizing the system shows it holds pressure adequately and no evidence of leaks anywhere.
A vaccuum check through the system shows no loss of vacuum.
Both leakdown and compression checks show a loss of 20% at cylinder 2, however was able to be improved with a trick of the trade of Marvel Mystery oil in the combustion chamber, which may have corrected a stuck ring.
I may do another compression check before we tear it apart and if its still stable, who knows maybe its elsewhere?
I just finally heard from a friend of mine who works at a dealer in the west and he's not so certain its a gasket either. He felt check the gasket at the oil filter housing as sometimes those leak as well.
Outside of this, the Explorer runs excellent, and am still very happy with it.
