My 2012 had this same problem. Replaced the battery and it hasn't happened since.
Had it occasionally on my 2014 Lincoln MKT and now on my2017 Platinum. Never bothered taking the MKT in for it and will see about the Platinum. On my 2011 Ex they replaced the module but it began doing it again later. Left it as is.
not sure if the newer ones are different but the 11 Exploders I opened the wiper switch up and it was made with flimsy contacts, if you're not sure if its bad just replace the switch because it will probably fail anyways if you use the wipers often. Its best to order with the vin number since they had a few part numbers, the new part had slightly different markings inked on it when I had mine done but double checked it before opening the wrapper, maybe upgraded part?
This problem is the reason that I joined the forum. 2011 Explorer 150,000kms and the wipers won't shut off. I ordered a new switch today as that seems to be the typical culprit.
