Anyone Know where the EEC power relay unit is???? | Ford Explorer Forums
tstaples
grafton, ma
98 explorer
Anyone know where the EEC power relay unit is on this engine? I cant find any mention of it in the Chiltons manual i have. I have a 91 explorer V6 i think 4.0L 4x4.. looks like this
its in the fusebox... tis labeled too once you are inside of it.... over behind the battery
well.. that's the ECC fuse.. but i'm wondering where the relay is
there are 3 relays mounted below the fuse box on the 91-92 4.0L Explorer.
The green I believe is fuel pump relay and the brown is EEC. The third relay is for the A/C WOT.
the box is simple to remove, it just presses in place and unlocks with a flathead screwdriver.
Hope that helps!
Yes, As 410fortune said. It's under the Fuses. Passenger side Fender. The Fuse case snaps off metal bracket. Very tough to get off the first time. I put a a little grease on the tabs and it worked much easier the second time.
One of the large black square fuses inside the motor. Under the cap will read eec/iso. Those are relays called fuses.
