So here she is as complete as I can afford for now. Now I can pickup where I left off over a year ago.
Hopefully, she won't need anything for a while. I picked her up last night and she still ran like a champ. Pulled slightly to the right but these are old tires and rims off of my '98 and they did the same thing after an alignment and balance on that one too. The alignment shop said that the camber was out but it didn't need a camber kit. Might be because I have never had it aligned and I put ball joints on it in December before it was wrecked. Not quite sure if that makes sense because I'm not too clear on what all goes on with the different parts of alignment.
Luckily, she was done just in time. My other Explorer seems to have some kind of fuel issue that will be addressed over the summer. Left me sitting at the bank yesterday morning but I could smell fuel after turning it over a few times. Then it all of a sudden fired right up. Guessing it isn't the fuel pump but maybe the fuel filter? It's done it twice now and it has about a 1/4 tank left.
So with the green Explorer I don't have a long list until she's back to the way I bought her but I want to go back to the way she came from the factory then maybe some light mods. Not quite sure yet. Here's the list of what I want to complete by summer:
Replace passenger step molding
Get another headliner
Reinstall interior
Replace odometer gear
Replace dash bulbs
Fix shift indicator alignment
Replace driver side valve cover (has a hole rusted through and leaks)
Clean or replace EGR to get CEL to go out
Also my airbag light flashes anytime the vehicle is on. When I was still driving it, I took one of the airbag fuses out to install a remote starter just so I didn't have to worry about accidentally deploying the bags because someone else had left the harness under the dash a mess. The guy that did the body work said that some manufacturers require you to take the vehicle to a dealer if you have the fuse out and turn the ignition on so that they can reset the computer. He said that unplugging the battery might work also but the battery was removed in May and another one wasn't installed until September so that should've covered that. I checked twice, and all of the fuses seem to be in and OK. Does anyone have any ideas?
