Anyway to add a keypad? | Ford Explorer Forums
NHarris
Gillette, Wyoming
04 Wrangler, 08 Ranger
On my 05 explorer, it has the keyfob, but no keypad on the truck. Anyone know if there's chance to add a keypad on. I can get one in good shape at the JY for cheap.
Any ideas, comments?
Thanks,
Nate
EDIT: Found my answer, but in a ranger format... :)
The Explorer keypad works as an input to a module which then controls the lock solenoids. The module could be either the Remote Anti-theft Personality module or the Central Security Module depending on the year. In the case of your 96 Ranger, the module goes by the RAP name but it is probably a different RAP module than the one in the Ex Sport.
My 2003 Ranger has a CSM and I reprogrammed it with a dealer tool to enable the keypad function using the hexadecimal code from a 01~03 Sport Trac. A Taurus keypad was cut into the door and now operates the CSM unlock functions through a small diode adapter box.
Mine:
Can something similar be done on a 96 with a RAP? I don't know. It's electrically different from mine. Possibly with the right combo of parts and programming.
The easy way out: Ford sells a wireless, universal, self-adhesive keypad that functions and programs just like your keychain fobs. You'd be up and running in minutes.
Stick-on Ford accessory keypad:
I think the stick on would be a good idea... but I would probably take it apart and adapt it to a more flush mounted keypad. :P
wireless ay?....well i'll be f*****.
yeah. Add it to the list of everything else thats wireless on cars. The keyfobs are very handy. Great invention there.
Posted via Mobile Device
yeah its spun out how only a few years ago we only had keys and knobs and worse case scenario a coat hanger or packing strap would get you in if your keys got locked in the car (o.k a little bit more than a few years). now your buggered if your key fob battery goes flat...unless youve got a wireless keypad that is!
What will they think of next? Nate, be sure to let us know what you end up doing............:popcorn:
--Well they are quite pricy....about $80.00 :eek:
--I was on the ford truck forum, and the guy there did something really cool for his keypad. He placed this wireless one in his gas cap. So it was un-noticed, but in an emergency he could use it, and its out of the weather. Looks like the pictured got deleted, I wanted to post the pic... :(
I honestly thought it'd only be $50-60. I wasn't expecting 80.00 for a numbered keyfob.
Go figure. Is there anyway you can score a keypad from the JY and make it work? :dunno:
Now that I'm unsure of. I found a perfect condition keypad off an 06 X, but the question is, will the car accept the code???? I don't know if my security module (?) would be accepting of it.
I can't help you there, sorry. ;)
I'll just have to talk to the guys at ford....see what they say.
im pretty sure all key less entry ex have codes printed on the security module for the key code, only thing i am undering is if the wiring exists in the door, which i think is what differs on these cars, body harness does not have the wiring for the key pads.
i could be wrong but i never seen extra connectors on non key less entry vehicles.
Well I'll see what I can do...right now I have a mustang to do A LOT of maintenance work on...so thats 1st priority...key pad can be second or third.
