Are all 95-01 Instrument Clusters the same? | Ford Explorer Forums
1997XLTRollover
1996 AWD 5.0
As the title says, as long as it's visually the same as mine with the tach, will the speedo and electrical connectors hook up? This is for my 96 V8. My local yard has about 20 95-01's mostly newer years and I'm trying to match my mileage, so I'm hoping all 95-01's are the same and I can use any cluster but want to be sure.
TIA
The Connections on my 1995 and my 1997 explorer are the same.. if that helps you any...
It does because I would say at least 95-96 are the same then and maybe early 97. I'm just wondering if when the speedo sensor went from the gear to the electrical connector if the cluster is different. But I'm thinking it's not. Just don't want to waste my time/money getting wrong parts.
I may have to pull a few trucks at the yard apart and look to see if there are any differences.
Probably the Best choice for you buddy...
i dont think theres a difference, the only difference i can think of is when changing to the white gauges you have to swap a few pins for the door ajar light and fuel reset
Ok well I ended up grabbing a tach and odometer from a 98 mounty (cheaper than an entire cluster). It's different. Very different. Now that being said, the differences were not unworkable but there are definitely different clusters by year. I grabbed this one because it was literally only 500 miles more than what my truck has on it so it matched almost perfectly.
It was however GREEN, my cluster has the blue backing so my other gauges did not match. Now this may not have been an issue if I was using the entire 98 cluster. The other issue I had was my idiot lights were in different spots on my 96 cluster vs the 98. Again if I had swapped the entire cluster this issue probably would have fixed itself because of how the newer cluster was wired to work with the newer gauges.
In a nutshell what I did was used all my original parts but put only the odometer in behind my original gauges. I haven't driven the truck far (just up and down my driveway at 35 MPH) because it's not registered, but all appears to be working.
My best advice for anyone in the future, grab the entire cluster. Don't try to save a few bucks and just change a specific gauge unless you look closely at part numbers and any differences before purchasing.
Good to note!!! My dad changed his gauges out in his 1995 f-150 with that of a 1997 f-150.. It was similiar, however there were small differences in the finish of the gauges.
