You could use brake cleaner spray to clean it out, but you still have to use a valve body lubricant after that. The brake cleaner spray will remove any oil, or lubricant that is inside of it. If no lubricant is used, the parts will feel very stiff, and be like rubbing metal against metal while it is being assembled. A little lubricant is all that you would need.
