I have a 1996 Explorer 4.0L sohc and I have no cruise or o/d lights on the dash after pushing all the buttons. Any ideas.
Build date 10/96 yes sohc . I don't know about recall I've have not had the car long and as for lights nothing when ing turned on
Does the "O/D OFF" light work during the bulb check? (key in run position, engine off).
Out of curiosity I just did key on engine off and it does not check that bulb, so I started it up and pushed that O/D button and the light then turns on, so I'm not sure if it works with the key on engine off test.
I went ahead and replaced all the bulbsIf you do end up pulling the cluster be sure to replace the 6 instrument illumination bulbs while you're at it.
The reverse lights are on the same circuit as the OD switch. If those work the circuit is at least partially powered.
Isn’t a build date of 10/96 a 97?
