Auto Engages 4WD Low | Ford Explorer Forums
sbanek
Detroit, Michigan
2002 Explorer XLS
On 2 Occasions my 2002 Explorer XLS has auto engage 4WD Low. Both times I had to stop the car put it in neutral, press the brake and press the 4WD auto button. Can anyone help with this problem?
Hmm sounds like either the 4wd computer is going out of wack, or the switch is shorting. Until you get the issue fixed, disconnect the shift motor -- that will prevent the vehicle from engaging LO range.
