oharris
- October 31, 1999
- Peyton, CO
- '00 XLS, '07 Mountaineer
My left auto hub has gone south again. This is on a '94 Explorer, and the hubs are a little different than the 91-92 hubs. I understand that there is a plastic cam that breaks on the earlier hubs. What is it that breaks on the 94 hubs? Are the earlier hubs more durable? Would it be worth switching over? If you look in the hub, you can see a three pronged sleeve around the perimeter. Compared with the right side (which still works beautifully), those prongs are much lower, probably by 1/8 inch. The first hub which was replaced last year is exactly the same way. It's as though a spring has broken inside. My snap ring pliers are too big to get at the snap ring in the center so I haven't been able to take it apart. Is this what's happened?
I also tried jacking up the wheels and running it in 4WD to see if I could get it to engage. It made a clicking sound as though the teeth were running over each other. I found if I spun the wheel to match the speed of the shaft, I could sometimes get the hub to engage. I'm now wondering if I put a spacer under the cam on the spindle which would force the sleeve further into the hub if it would engage. Has anyone tried this?
I know the best solution is to convert to manual hubs, but I really would like to keep the auto hubs if they would be reliable. The main reason is, I want to keep the ability to engage 4WD on the fly when it suddenly starts snowing on the interstate. Pulling over to lock manual hubs is a good way to get rear ended.
Thanks in advance,
Oliver Harris
'94 Explorer XLT, 5sp 4x4
Thanks in advance,
Oliver Harris
