MANZ
- September 5, 2001
- Olney, MD
- '94 XLT
I searched for a bit about this problem and couldn't find anyone having the exact same symptoms as mine. I'll try my best to describe it ('94 XLT - 105k).
While driving along WITHOUT 4wd engaged, what sounds like the left hub starts to grind like it is trying to engage. This seems to happen only while taking a right turn, and happens intermittently. If I engage the 4wd, it will go in fine (with the usual loud clunk and popping) but then there is an excessive vibration/wobble that is proportional to road speed and the truck tends to pull left. I don't know if the wobble and the hub grinding are related. I was thinking rusty u-joints since I rarely use 4wd. It will come out of 4wd ok, but the hubs will grind for a little while like they arent fully disengaged. I have to go back and forth a few times until they quiet down for a little while.
This morning it happened again, and actually completely engaged the hub (I could tell from the vibration) without ever touching the 4wd button. I had to back up to get it to disengage.
Yes, I know I should put in manual hubs, but I can't figure out why the hub would be attempting to engage if the front axle isn't turning. I have had them out and cleaned and inspected them a few times. No, there is not a bunch of grease in there and everything appears to be in OK shape.
Logic would tell me that the axle is turning somehow (a little at least) to partially engage the hub cam (I don't think the t-case is dragging or engaging at all). Manual hubs still wouldn't solve why the axle is turning somehow.
What the hell is causing this, especially when turning right? Am I missing something obvious? Thanks in advance for any ideas (besides lighter fluid and matches).
