theMagnumHeart
- August 24, 2008
- Clark County, Ohio
- '94 XLT Eddie Bower
I know most of the time when you turn around corners or curves and your hubs make a rattling sound or a clicking its from where they need to be cleaned or they are just worn... but sometimes, not all the time, when I engage 4x4 and use it for a while then disengage it i will start driving down the road and all the sudden it sounds like an airplane is taking off inside the truck, but its coming from the hubs... it sounds like they are partially engaged... I can stop, put it in reverse and go back around 10-20' and go back into drive and it fixes the problem until I next use the 4x4, or I can simply slow down engage the 4x4 on the dash sit a second or so, and disengage it and it also fixes the problem...
is this just caused from dirty/worn hubs?
Also when Im in 4x4 high range sometimes either one of the hubs, right or left, will "pop" making a loud thud like its not locked in all the way
