BIG COUNTRY
- April 11, 2003
- EIELSON AFB, ALASKA
- 1998 XLS 4x4
ok...i have 2 mirrors...1 problem for each...for one of the mirrors the bracket the goes onto the mounting was cracked and the other one, the stem piece is loose and my mirror falls off...so i decided to go with the mirror that has the cracked bracket and replace the bracket with the other mirror, but in order to remove the wires out of the bracket i had to cut the wire from the sensor...so i did that and put the new bracket on, soldered up the wires and put the mirror in...everything works...however before i did anything, everything worked on both of them, the autolamp would come on at a certain darkness...now, the headlights come on in bright daylight everytime i push the button....i couldnt of have mismatched the wires, cuz 1 was copper, and the other one was silver...so its actually fool proof...so what else could it be???
