RER_98FRXLT
- June 5, 2011
- '98 XLT
98 XLT, 4.0 SOHC, AWD, Auto - 191K
I have no record or recollection on last changing the transmission filter and adding or changing fluid. I have been convinced that flushes are a bad idea and just plan to drop the pan, change the filter and replace the 5 or 6 qt loss.
However, if this was last done at a quick change joint, I am concerned that some fluids may be incompatible with others. Is this a risk?
I plan on using Mercon V as specified.
All input appreciated. Thanks
