gianclaudio
- April 17, 2003
- Panama City Central America
- '97 XLT
Hi, my name is gianclaudio, I owe a Ford Explorer XLT 1997, and I am having a transmission problem.
Ther "check service" light is on all the time and the reason is because when I ran a computer tester for Fords, it showed that the first gear is not kicking in, I always go from stop to second gear even if I step real hard on the gas.
I took the transmission down and found out that the preassure valve was getting stuck, so I kind off fixed it but then when I was driving to the mountains, I took the overdrive off, and the problem kicked in again, and I haven't been able to fix it.
Once, I had a load of about 50 cement blocks in the back, and when I was going up a hill which was very steep, the first kicked in and the light went off for a while but then came back on and the same problem, the car goes from 0 to second gear always.
Can you give me any hints, besides buying a new transmission? =)
I really would appreciate it.
Sincerely,
Gianclaudio from Panama Central America...
Sincerely,
