Aux. Tranny Cooler | Page 2 | Ford Explorer Forums
Aux. Tranny Cooler
that cool yeah i think i am going to by the fle o lite cooler do you know where your going to hook your fan up two
:redexp:
I'm going to use a water temp switch set for 180F.. to trip a relay to run the aux tranny cooler. The fan power will be direct from battery (with fuse of course).. that way it will run a bit after the truck is off if it is too hot..
I'm also working on adding an aux fan to the radiator/ac that will run if the Radiator is over 190 when the truck is off so it will cool off the truck when sitting..
When its over 100F out here and you have to stop somewhere then leave in 10 minutes or so the truck is much hotter when I restart it than when I left it (heat soak)..
~Mark
Tranny Cooler Pic
OK OK everyone sit down I know this is exciting :D
I posted two pics in the explorer gallery of my cooler install. Basically just where its mounted. I have not plumbed it yet, I am having a hard time finding 3/8 inch tans hose, so am going to hot rod it with some AN stuff and hard line I have sitting around(well.. some of it I have sitting around). Thought you may want ot take a peek, I have no Idea how to post it here, but he is a link
http://www.explorerforum.com/data/s...=SteveVB&cat=500&perpage=12&sort=1&ppuser=615
I guess you can attach a file to the post, but since its in the gallery no need to take up more space.
