Axle Breather/Vent | Ford Explorer Forums
Axle Breather/Vent
dvonwwe
Miami, FL
2001 Sport Trac
I was inspecting my axle tube breather on 2001 Explorer. The breather is made of plastic. The end, which appeared to be a cap or something broke. The rest of the breather is ok. Will it have to be replaced?
You want something on the end. Its just a vent and you don't want it sucking dirt in.
When I extended our breather lines I ran them under the hood and then just grabbed a PCV/valve cover breather/filter thing. I'm using that filter to keep dirt out of the line plus with it extended to under the hood I don't have to worry about water etc getting sucked in when I go through water that is over the axle.
BTW.. I'm moving your thread.. I don't think you meant for it to be in the suggestion forum.
~Mark
Hi Mark
sorry i posted to the wrong thread. where did you say you moved my thread to?
Your actually in the new location.. When you clicked on the link to come back to the thread it took you to the new one..
Its in the 1995-2001.../Stock forum...
When your reading this, look up and you'll see where in the forum you are.
~Mark
Yes, you can put another end on the hose or put a panel retainer pin in there.
