simonusa0
- October 29, 2007
- MI
- 2003 Explorer XLT
Problem: Drumming from rear end.
My 2003 XLT Explorer now has only 46,000 miles. The rear axle was rebuilt at 31,00 miles under warranty (whine) then again recently at 46,000 miles after winning a HUGE battle with Ford and the dealer. Got it back....whine gone but now it had a drumming vibration at 65mph plus. Took it back. Dealer, agreed, tightened axle mounts, noted an improvement then finally stated tires were out of balance (I know that was a cover up because tires had only 1,000miles on them, I'd also had them checked again day before I took the truck back. 58 miles put on truck and empty tank!). Dealer stated all uj's, cv joints and wheel bearings are ok. There is an improvement .... but I can still feel a drumming from rear end at 75mph and up.
So I checked the rear end myself (on axle stands) and looked for movement in the CV joints and couldn't find any. What I found is that I can move the inner CV joint assy up and down (with associated noise) where it enters the axle/diff on the driver side . The other shaft entry to the differential on pasenger side is ok. (Do not confuse with side-to-side movement of the cv joint/ shaft assembly which is normal).
Can anyone comment if any play with spline/cv assy's fit into the axle is acceptable? I think this is the vibration root cause. Comments most welcome. I haven't gone back to the dealer yet....I just hate the grief and confrontation!
