Did 5-Speed Swap now vibration @3K RPM??? | Ford Explorer Forums
DieselHilux
95 ford contour
Title says it all, swapped a manual trans out of a 03 F150 V6 into my 97 mountaineer and now I have what seems to be an engine vibration around 3000 rpm.
I used a 50oz flywheel for a 96 F150 with the 302 and I assume it only bolts on in one position????????
I am at a loss with this one and its really irritating me :mad:
Have you looked over the crossmember mounts and the engine mounts and make sure you do not have a broken or dry rotted rubber mount? And have you checked the driveshafts for bad u-joints and or a unbalanced shaft?
It was the damn trans crossmember, it positioned the engine so that the front of the oil pan was contacting the steering rack and transmitting a vibration through the vehicle.
I modified the crossmember and all is now well!!
(Modified it by making in so that the trans sits lower by welding a flat plate onto it after cutting it)
