jrgaylor
- April 15, 2002
- Washington
- 1985 BroncoII
I have a D44 from a 78 F-150 that I have swaped into my 91 explorer.
I had new gears,air locker,and bearings ans seals.
The problem is the axle tube seal on the long side is leaking, so I replaced the axle with a yukon 4340 unit thinking that the grooves in the axles from the old seals was causing the leaks, but the leak was still there so I replaced the new seal that was installed when the gears and locker where done with a new seal and it still leaks.
I am now not sure what to do??
When I got the D44 some of plug welds in the long tube where broke so I re welded them, how would you go about seeing if it was bent?
However I am getting very quick at dissassemble of a 44
