- November 6, 2000
- 2018 EX Sport Concept
The rear diff has been leaking for some time now (probably years) on the right side, all around the axle tube. While it's not much of a problem and is hardly any fluid (looks worse than it is with the thin film of gear oil spread out), I'd like to fix this. I've been planning on welding the diff to the tubes to prevent spinning anyway, but would that be a fix or is there another possible issue? I don't see any cracks on the diff or tube, I don't think theres a seal other than the press fit of the tubes into the diff, and all the factory plugs are still intact, with no seals leaking, either. Also, when welding the diff, since it's cast iron, do I really HAVE to use hi-nickel rods to do the job right, or will a wire welder with flux-core wire do the trick? Suggestions and advice appreciated.
