B&M Slapstick, Where to get the bracket | Ford Explorer Forums
B.T.O'Rourke
Gaylord, Michigan
'94X XLT(RIP), '92 XLT
I have a '94 Explorer 4.0 with a A4LD auto trans, I want to install My B&M light truck Megashifter, But B&M doesn't make a bracket for the Tranny I have! Does anyone know of somebody who has this bracket or knows what I have to do to Fabricate this thing??
Is your shifter designed for a 4spd automatic? If not this will be one of the biggest obsticles you'll have to face. Most aftermarket shifters are only designed to run the older style 3spd automatics and if you install one on a 4spd you will not be able to manually put the transmission into low (1st). If your shifter is designed to work with a 4spd or you don't care about having the ability to shift into low all you need to do is crawl under your X and compare all the bracketd provided in the install kit that came with the shifter untill you find one that looks close. You may have to tweek it or redrill a hole or two, but it isn't that difficult.
