back glass rattle.... | Ford Explorer Forums
97WillowXLT
Roanoke Va
'97
my back glass rattles like no other....
anyone that has thought of anything to help it out somewhat?
tighten the bracket that the window fastens to..... you can move the bracket, just push it back so you have to close your rear glass harder......
we had that problem on Spas' Ex. Oddly enough it was one of the shocks and not the adjustment. There was a bushing missing on the pin that held the shock to the glass. I put some gasket material on there and that did the trick.
If it's the window itself you can get some sticky back foam weather stripping from Home depot or someone and put a strip on each edge of the glass. It will give it a tighter fit.
Once you get to a certain point and see the glass flexing it's hard to stop it.
