The windsheild wiper cause alot of noise against the back window. Also take apart the back panel on the rear door. Stuff tons of shirts or old towels that will help out alot. Dynamat works wonders if you want to spend money. In your case i would get a whole bunch of the cheap original dynamat and just layer the heck out of that back lift door. Dont worry about getting the expensive Extreme dynamat for your application. What would give you a little more bass and stop the rattle all together would be to build a bottom firing box. Have the woofers face the ground and have the box on stilts. You still get a 3db boost. The same as you get from firing the subs backwards. This though will get rid of the rattle.
