Fbird
- December 11, 2021
- Atlanta, GA
- 2006 Explorer Limited
06 Limited. I anticipate installing a rear camera with a mirror cam. In powering up the rear (little red wire from the camera) this needs a 12v source from the back up lights. I have probed the light socket for my 12v source...NOW the question. In my experience with my 03 windstar I did this exact same thing ONLY the GEM module had so much bleed thru voltage that the mirror THOUGHT it was in reverse all the time. (only takes about 30 ma to activate "rear view camera).
Is the Explorer set up the same way? by having a GEM module? If you put LED lights in the reverse plug will they stay luminated (the Windstar would as they only need about .5 amp to light up dimmly)
I like to be fully prepared when doing tasks so if I need to add an electronic relay in line to close off the voltage that is doable but would like to know ahead of time.
Thanks
Thanks
