mhoffman13@insig
- February 9, 2009
- Louisville, KY
This is weird, anyone have an explanation?-99 Explorer 4WD V8, neighbor had to jump start on intertmittent basis. I charged batttery, removed charger and measured 12+V after batt rested a few minutes, (I know fully charged battery is 12.5-12.6V), anyway started car. Got 14+ volts while running (assume charging system OK). When shut off heard clicking from the relays in pwr dist box. Relays 8 & 10 (in lower right corner of box closest to driver door) were both cycling on and off. These are supposed to be for horn, washer pump or fog lamps or other depending on source of info.
I measured a drain of 2 amps. I removed relays and drain went to a few milliamps. Car failed to crank next day so I tried re-charge but it would not take, measured 11 V after charge attempt. Put in new battery and low and behold, put relays back in and they no longer cycle-was a rainy night so did not check drain. I will monitor neighbor's experience next few days. Any ideas, anyone.
