Bad Cold Idle | Ford Explorer Forums
Bad Cold Idle
nickrahn
Loganville, Wi
92 Eddie Bauer 4x4
The ol explorer seems to not wanna idle on cold start up. it will start and the idle will pulse and eventually die, I could restart it 10 time when cold and it will keep stalling. I thinking throttle position sensor, EGR or Idle Air Control Valve. can anyone confirm before I spend the money? It seems to run fine after warm up.
Unless Ford did something really weird with your '92, it won't have an EGR system so I wouldn't think the EGR is a possibility.
TPS or IAC could be a possibility. If it's the IAC, it's more than likely just dirty rather than in need of replacement. TPS is a simple potentiometer and can be tested easily enough.
In addition, a dirty MAF could cause those symptoms, or a fuel delivery issue, or a vacuum leak, or who knows what else. Before I started spending money on parts, I'd spend some effort in diagnosis. I'd probably start by pulling codes (see stickies in EEC-IV forum) and checking fuel pressure on initial startup.
I cleaned the MAF sensor and I did the CEL tests. Key on engine off, 111, 124, 157, 158. and Key on engine on, 412 was it. after the test I cleaned the MAF sensor. did not test again to see if it helped. the 124 code was for the TP sensor. so I was thinking that's why it was in need of a changing.
uh
So I was curious, I unplugged the idle air control valve and there was no difference. so I took it out and I find that it has wet black stuff in it. Carbon or oil I suspect. so I cleaned its insides and wire wheeled the outside to make it pretty again then reinstalled it. I also gave the idle adjustment screw a few turns to raise the idle and it seems to idle without stalling now at about 500. it seems to be rough still though.
