Bad Transmission will this work | Ford Explorer Forums
rmeken
Ok I have a 2002 with 137,000 trans is slipping and took to shop wand was told it need to be rebuilt it is 5755s
I have a friend that wrecked his truck and it is 5r55w
Can anyone tell me if this 5r55w will work with out any problems?
Thanks
Ken
I dont think it will work - I think the bellhousing patterns are different between the S and the W.
Welcome to this forum! Keep in mind that most shops will say that it has to be rebuilt. What are the symptoms? It could be something like the solenoid block or worn servo bores. Do you have a flashing overdrive light?
Yes it was slipping between 3 & 4 gear also OD lite was flashing
I had shop change fluid and it seem to help a bit but I am not driving it
So it still will give me code when i use that code tool? Sorry for dumb questions
Well my reader does not do trans so I guess I am out of luck
What I dont understand is that Tag on door code is "V" 5r55s
But everywhere I look it says it should be 5r55w
i have 2002
BrooklynBay is right. The transmission shop will usually tell you it needs to be rebuilt.......usually without even looking at it. Several months ago, I e-mailed a transmission shop about my transmission when it first started slipping, and the guy told me it was probably the torque converter ---- which is "only" the most expensive component in the whole transmission. (Crooked b@st@rds) I know there are some honest mechanics, lawyers and politicians out there....somewhere. Keep in mind there are at least 6 or 7 "minor" things that you can do that might fix slipping before doing a rebuild. These include a simple clogged filter, band adjustment (tightening a bolt), changing a valve body gasket or plugging in a new shift sensor solenoids. Good luck.........you've definitely come to the right place. People on here really care and you're in good hands with BrooklynBay.
FORD Transmission DTC - Diagnostic Trouble Codes. OBDII P0700-P0790.
Also, have a look at this.
It may be possible that you only have a faulty pressure control sensor. If your transmission shop pulled that trouble code for you...........then they already know this. But, no dealership or transmission shop ( I know of ) is going to let you walk out the door with a slipping transmission for only $100 bucks - including labor.
Before you rebuild that transmission, at least replace this sensor for $27.95
http://800700tran.com/prod.itml/icOid/153
i got this website from BrooklynBay a few months back. Even if you eventually rebuild the tranny, you'll be buying this piece regardless. So....at least give it a try now.
Also, get a quote from your transmission shop for the rebuild. For me a remanufactured 5r55e is about $600 with shipping. I can disconnect everything from my tranny and get it ready to be lifted and swapped out. So, I called several auto shops and asked them "how much" to unbolt one and bolt the other one in and I would do the rest. One guy said it would take about an hour and would charge me $100. All-in cost would only be about $700 vs. a $1,000 - $2,000 (rebuild) depending on who I called. Hmmmmm ??????
Ford OBDII Diagnostic Trouble Codes - P0700-P0799 - Transmission
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear I Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stock On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stock Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
Ok what I do not understand is that the Tran code on cert Label on Door is "V" which is a 5r55s but everywhere i look on net that was not in this Explorer until 2004
So how can i tell what the heck we have?
Explorer (4.0L) 95-01 4 Rwd 4R44E, 5R55E
Explorer (5.0L) 96-01 4 Rwd 4R70W
Explorer (4.0, 4.6L) 02-03 5 Rwd 5R55W
Explorer (4.0, 4.6L) 2004 5 Rwd 5R55S
I assume you have a V-6 ?
according to the Hollander interchange manuals, a 2dr Explorer Sport and a 4dr Sport Trac both have a 5R55E tranny.
the 4dr (non-Sport Trac) Explorer should have a 5R55W tranny.
whether or not the Hollander manual is correct, I can't testify...Ford is notorious for changing things in the middle of model years.
J,,,,get a 2nd opinion before committing to any repairs...do a search on this forum, too.
Yes it is 4.0 and is a full size Explorer 4 door RWD
Where on the transmisson is a "TAG" that i will be able to id trans?
According to the trouble code, you may only need the electronic pressure control solenoid. That e-bay module looks like everything. And, it is all used. If you put the used module in and it doesn't work ......... you won't know if the used solenoids are bad or if you have other problems.
