FL-Gun-Nut
- March 1, 2017
- Eustis, FL
- 2007 Ford Explorer XLT
Hey guys, first of all, I did a search on here and couldn't really find anything similar to what I am experiencing.
2007 Explorer, 4.0 V6, 2WD, 115,000 miles.
Just recently, after fleeing Hurricane Irma in Florida and driving to Michigan, the "Check Charging System" light came on. I had the battery and alternator tested. The alternator was bad, as well as the battery. (Florida heat will murder a battery.)
I replaced both of these parts 3 days ago. All was well after the install.
Tonight, I'm driving home from a short trip to Taco Hell and again, the "Check Charging System" message popped up. When I got home, I checked all of the bolts on the alternator, the positive battery connection, the harness connections, the belt tension, the battery cables and everything else I could think of. The only thing that looked suspicious was that the positive cable from the alternator to the lower engine area was close to the water pump pulley, so I tucked it up behind a line.
I looked at the harmonic balancer to make sure the rubber was in good condition and it looked alright, I couldn't notice in play in it. Also, had the wife jump in it and rev it a few times to make sure the belt was keeping up with engine RPM's.
I'm at a loss here.
I'm at a loss here.
