RileyJR
- August 2, 2021
- Alabaster, AL
Ford Explorer
Limite
I’m having trouble with the charging system. This is the :
I have replaced the:
I Replaced batt & alt last week, got the charging light and had cable corrosion, so replaced with new harness.
Everything is nicely connected. Battery holds 12.5 - 12.9 volts, when running alternator puts out 14.5 (ish) volts, pending if AC is on or not. So the system is charging.
Everything works, lights, radio, ac, windows, locks, turn signals, auxiliary connection. Have checked all fuses, all are good…no burns or blown fuses.
At least, in all the fuses where the filaments are visible.
Took back to O’Reilly’s and all power units check out to what I got on the voltmeter. So battery, alternator and starter are good. (only a week old).
Put new spark plugs in as well since I had both sides exposed. Engine is quiet.
Belt is in reasonable shape, no frays, no wear spots, no sidewall damage. I’m saying this as I have seen harmonic balances as the culprit on a couple forums. But no vibrations or power loss.
Hoping someone may have some insight or experience with an issue like this. Very frustrating and now costly ($500+ In the last week).
Worried it may be the ECM/PCM. Or will be something silly light the dash lights which we’re getting notice dimmer over the past year.
Also, bought an OBD2 tester kit and pulls vehicle info, alt/batt tests the same as above. No real faults codes as of yet, but still figuring it out.
Thanks,
John R.
- 4.0 L V-6 with 181K miles.
- battery
- alternator
- complete wiring harness system.
Thanks,
John R.
