bagged pictures | Page 3 | Ford Explorer Forums
bagged pictures
I don't know much about raising/lowering, except that i want to go LOW too, but how bad is that gonna tear up your tires? The camber looks to be 20-degree sout of spec
when you lift or raise your truck the alignment will change through the arc of the circle. Not sure how high he lifts his to drive but my ranger has just a slight bit of negative camber when I drive.. Of course mine isn't a daily driver so it really doesn't matter to me..
Here is a picture of my truck lifted
here is how it looks when its lowered
My truck can go from negative camber to a little bit of positive under full lift..
yeah, mine will wear the tires better than it did when it was lowered 2" up front (if i choose to be relatively responsible)
i can set a ride height that will wear the outsides more than the insides even if i want
i'll get a better pictures of my viair 550c later!
thanks for the compliments guys
wat up hey expo5.0 how hard was it to bag the front. i got a 99 sport that i wanna bag so bad i can taste it. i was thinkin about doin shockwaves up front and bags in the rear what do you think. how did you do the back was it just a frame notch or what to lay it on the ground.
me and my buddies at my shop reindexed my torsion bars fo a weekend that was not fun my 20s kept rubbin and i couldnt turn for nothin. how much did that whole setup cost. im ballin on a budget, and i am gettin the system put together 6 12 kicker comps on a 1200 watt kicker amp, alpine deck, and alpine 320 for the front and rear speakers. got three subs so far runnin at 1 ohm. gonna have to do some tricky wiring for all 6 on that one amp to make them run at 2 ohms. let me know what you did i want bags damn it
bags as they sit now are roughly $1300 invested.
is your sport 4x4?
I would say stay away from shockwaves on the front of a vehicle.. Especially a truck.. I've heard way to many horror stories from them. Plus a friend of mine had them on the front of his blazer.. Didn't last to long till they broke...
If your going to bag it.. Use bags..
