baillie
- August 23, 2008
- Auckland New Zealand
- 2003 V8 LTD
My battery only gets charged up to 11.8. If i leave the interior lights or radio on for any lenght of time the battery will not start the vehicle. I purchased a new battery specified for a Explorer, and still it only gets charged to 11.8. So i recharge the battery using a 8 stage CTEC smart charger. The Ford dealer has removed the Alternator and has had checked reporting it is okay. With the vehicle idling and with all electrics on including high beam i measured the current coming out of the alternator at 13.8volts.The dealer commented that 13.8 is within spec, and the battery must be the problem, Ford has no idea why i should have a problem and they can't find a TSB. Returned the battery to supplier who recharged it and load tested it and found no problem and fit for purpose. So i wondering if you had a suggestion on why i would having this problem with a under charged battery? The vehicle has travelled 110,000km's. Regards Michael from New Zealand
