DrHerbertWest
- May 5, 2007
- Omaha,Nebraska
- 99 mercury mountaineer
I recently purchased a 200amp alternator from http://www.highoutputalternator.com for my 99 Mercury Mountaineer 5.0L, I also picked up a yellow top optima battery.
The day it came I installed the new alternator, the pulley on it was to large and caused many problems. I switched the pulley with the stock one.
Now ever since I have installed this alternator I have had weird problems, my battery gauge is normally sitting at low and will go up when I rev the car. I checked the volt on the battery with the car off and it was at 12v on it was at 14v, so it seems it's working right. This is my setup I am using when I put the alternator in I also installed a 1800 watt true sine power inverter. This install was done by a professional.
The blue wires are all 0 gauge, also the other day it started to have more problems, if this is related to this I doubt it, but the car started to idle rough then the check engine light came on, error code was P0303 cylinder 3 misfire, plan to look into this today.
Thanks for your time.
