zavetsky
- August 6, 2000
- '94 XLT 4x4
Ok...had my front pass. side caliper lock up today...what fun........(just had the rear brake cylinder blow out just a week ago so I replaced both of those and the brakes back there).......
So, I figured I might as well replace both, have the rotors turned, replace the brake hoses and replace the bearings, etc.........do it all ($$OUCH$$)
I took the rotor to a local shop to turn and they said the bearings and ABS sensor have to be off first........
SO...how hard is it to get that ABS sensor ring off and shoudl I have to remove it to get the rotors turned!?!? I assume the bearings are your standard type, where inner and outer races have to be beat out as well.....
Also worried about how easily the brake line will disconnect from the hose fittings.........
Anyone been there, done that?
Any tips would be very much appreciated..........I am doing one side at a time (what a pain)..........I have everything apart except for the ABS sensor and bearings etc..........Would like advice BEFORE I screw it up!!
Thanks in advance!
Thanks in advance!
