CodePoet
- July 11, 2002
- Indianapolis, Indiana
- 1993 XLT
Hey guys, I don't post around here much anymore. But have a question that you all would be very able to answer.
I need to beef up my tranny crossmemeber abit. I'm going to run a vertical piece up the frame rail starting at the tranny crossmember. The entire crossmember, including the RA mount portion is bolted together. The load should transfer to it just as it would if I started the extra support at the 2x6 portion. Am I correct with this thinking? I was thinking and three bolts in on the vertical portion like the cage ra mounts. Think this will work the way I want it to?
Paint-O-Cad version
I have the material to make a 6" vertical part as well if that would work better.
As it sits now
Paint-O-Cad version
As it sits now
