gstuartw
- July 24, 2011
- Lewisville TX
- '11 Limited
Of course many if not all of us frequenting this part of the Serious Explorations forums are interested in some level of modification to their vehicle. I just want to warn all of you interested that before you modify any part or remove a part you make sure you can get replacements.
I'm in the process of doing some mods on the Explorer I bought 6 weeks ago and have stumbled onto an issue I never anticipated. I removed the plastic trim with not enough regard for the little clips that hold the trim on. I figured they'd be inexpensive and easily sourced at the dealership. Not so! The dealers don't even carry the clips for the wheel arches and sourcing them is not easy as you have no part number to go on. I'm making my way through the process and sourcing after too many hours on line and not enough time on my back in the garage putting my X back together.
I've seen other posts here where members are taking parts off and cracking them open to add LED's or what not. Some are finding out the hard way that while the parts might be available they are not cheap. In my case they are a sub component to a much more pricey part.
Do your homework, don't rush into a mod until you know well and good just what you are taking apart. I wanted to have the trim on my painted to match the body. To save some money I figured I'd remove them myself. I may have saved a couple hundred bucks up front but on the back end I've probably spent more. So far I've purchased; rattle can paint and clear coat for the back up sensors the paint guy was worried about painting, tools to remove the fasteners, fasteners I've broken. Then there is the cost of my time and aggravation...
So please heed my warning. Have fun and be creative with making your vehicle your own but think about what you are about to embark on. This after all is like any DIY project around the house...most likely to end up taking longer and costing more than you expect!
Cheers!
Cheers!
