Best coils for a Dana 44 swap? | Ford Explorer Forums
mcramer15
Alma Center, WI
1993 Ford Ranger
I am planning on doing a dana 44 sas swap in my 93 ford ranger. I am wandering what the best coils would be for this swap. I would like around 3 in.'s of lift and some coils with good articulation. If there are some coils i could get from the junk yard or off a parts vehicle that would be best due to lack of money right now. info or suggestions on prices and what coils would be best would be much appreciated. Thanks
Thanks for that!
You'll likely need a lot more than 3" lift to get the diff housing on a D44 straight axle to clear your frame crossmember for the engine (usually 6" or sometimes more is needed).
Figure about 2-3" more than what's claimed for a set of early Bronco coils used under a RBV.
3.5 In lift early bronco coils, from either Wildhorse or Jamesduff, both very good companies with a progressive rate coil. you will likley net 6in lift with them.
I would like to swap in a 302 sometime. should i get an even bigger coil to compensate for the heavier engine?
Also what is a good way to balance out the rear so it will be the same height?
