Solid Dana 44 swap done | Page 3 | Ford Explorer Forums
I know a guy who did an EB44 in the front of his Pathfinder. He cut and turned the axle and pointed the pinion up. Problem was, the oil didn't bath the ring and pinion enuf and he quickly burned out his front end.
Just my 2 cents.
Radius Arm Brackets
Kampy, You should have used the '79 Ford Radius Arm Brackets. The right one has one bolt hole that matches the Explorer frame.
I used them and it has worked out so far, they have a location to mount a transmission mount/cross member (Home Made of Course).
I want to add the new Duff radius arms down the road so I have only bolted the brackets in so far.
My Track Bar frame mount is made of 2x4 box tubing, 7/32 wall. Notched it to fit the frame and to clear the bar and movement. That worked out well and it is rugged.
The coil spring buckets are from an Early Bronco and welded in the same location as the Explorer's were. The height of the EB buckets and the Explorer buckets are the same and that sort of set me up to use EB springs.
The only problem I am working on now is the removal of the cross member, or I should say the replacement of it. I want to cut out as much as possible and then weld in a removable one, alot shallower than the original.
Time will tell.
Keep it on all four
