- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
On our 1992 I got our A/C to run almost 10F cooler by adding a heater control valve from a 1995 Explorer. It cost me $16.99 for the control valve (got it from AutoZone, a local auto parts chain store).
You put it just outside the heater core in the heater lines and run a vacuum line from it to a t (you add the t) for the blend door. When I change my controls from panel to MAX-AC it closes the blend door which then closes the heater control valve. Once closed it makes the water in the heater lines bypass the heater core. When I do this our A/C goes from 50F to 40F (thats with all the doors open so it is also using outside air).
It a cheap fix that Ford figured in in late 1994 (I told them 1995 since I knew all 1995's had it.. and only late 1994's did)
~Mark
~Mark
