ducefour24
- November 16, 2010
- Turlock, Ca
- 94 XLT
hello all
my name is troy amaya and i am new to this fourm
okay my problem is this ill give you guys a break down of what has happed
I bought my 94 ford explorer XLT 4x4 about a year ago and it ran fine untill bout 5months ago.
first my alternator ceased up on me when i was driving and broke my serpentine belt so i got it home and this is when it a started
i changed out the alternator and belt with new ones from autozone and the car ran fine for about 2week
then when i drove i noticed that my turn signals and ac and heater wouldnt work and my amps reading was low.
so i took the alt. back and replaced and got a new battery and it was fixed for a bout a month then it happened again but this time sometimes the amps read fine and the turn signals worked ac everyhting then i shut it off and start it and the amps would be low and signals ac didnt wrk it did this for awhile until finally the signals and ac heater stopped working 4 good
yet the amps were still low
i took it to autoaone and the batery and alt passed
this is where i am i can drive the car with a freshly charged battery for bout 3 days but slowley my battery drains as i drive until the car will just shut of while im driving i keep a spare bat in the back replace it and the car starts but slowly starts to drain and the cycle continues charge the battery run a while charge run awhile. yet the turn signals ac heater still dont work
ive checked the bat cables their good, tooken it to have the bat and alt tested and it passes
im doing the multi meter test when i get off work to see if i have drain will all this i kno its alot sry
what could it be
what could it be
