black smoke, miltiple obd codes, anyone of your guages not working? | Ford Explorer Forums
33exploder
Southwest Louisiana
93 xlt
eec-iv will never give a code that reads "ecm failure" it wil give any number of combonations of codes such as:
1. Maf sensor failure
2. Tp " "
3. O2 " "
4. Primary fuel circuit failure
etc...
Even with all these code it will still spit out this one (111) system pass and (998) operating in failure mode. You can start changing all you sensors, wire loops, bat cables and wouldn't fix anything. I chased this ribbit for 30 days. I tested each sensor, went to the parts house and tested their parts against mine. Only to get the same test results.
I am ready to junk it. I had one last part to test,the ecm. Pulled it out and called around to it have test with a b.o.b. (break out box) but no one had one so i did the old eye ball check, opened the case and found two little parts inside hangging on by one their two wires. Those two parts made all the above mentioned problems and codes. Keep in mind you can't just swapout the ecm with any old ecm you find in junk yard. It has to match the part number exactly. I didn't follow that rule, i put in the first one i found. It ran but very good,the timeing advance was off.
Back to the parts house with the bad ecm purchased a remaned ecm for under $300. Pluged it in,cranked it on.
fixed everything including the fuel guage
Sounds just like a bad ECM, wish you had asked around here first and I had seen it cause with all those faults I'd have steered you directly to the ECM.
I'm glad you figured it out and got things working again.
:thumbdwn:ha. ha. i did ask...
THIS IS NOT DIRECTED AT ANY ONE MEMBER.
You're 30 days late and $200 short
And those that did answer just quoted some handbook.
I read a lot of your threads, none of you have the ability to analyze facts and draw a conclusion without an OBD reader in your hand. "computers will make you stupid", computers are to help you with your thinking, not do your thinking.
unplug and do some independant analytical thinking!
eXcali, appreciate you taking the time to read my thread, GOOD THINKING:salute:
I call it my Dumb Phone, /seriously! No one can spell nor recall any phone number-NOT EVEN THEIR OWN, without apps. No substitute for Brain Storm Systematic deduction troubleshooting; its cool when tech corroborates my findings.
"What's Wrong with this picture...?" Remain calm. 😎
