Blend door fix. | Ford Explorer Forums
Blend door fix.
Tamijane63
St Cloud Florida
1997 Merc Mountaineer
The blend door fix that is addressed here is GREAT and worked PERFECTLY. This quick and easy fix worked and my AC is now working. Thanks very much for posting this great fix. My brother did it all himself and did a great Job. The only thing about the fix is adding that once you get the acuator replace it and then put the door in make sure the acuator stem goes into the blend door hole then seal the bottom area. He had a tough time getting the door and the acuator in the correct position. This has to be in the right position or it will not go in. Plus the actuator helps hold the door in place which helps you seal the bottom back up correctly. I cannot thank you enough for posting this great information to the public. My hat off to your experience and putting out this information to help people.
