Blower Motor Inop | Ford Explorer Forums
Blower Motor Inop
rsem
2007 sport trac ltd
2007 Sport Trac Ltd, V8, Climate Control
The Compressor comes on, but the blower motor does not. I checked the Fuse and the relay and they are both good. Tried to find the Resistor but it is not located where this forum says it should be, perhaps because I have Climate Control? Any and all Ideas/suggestions would eb appreciated. It's damn hot here in Florida.
Thanks
Ron
is manual a/c or automatic a/c system? manual has an actual resistor providing only 4 speeds. auto has a speed controller providing variable speeds. both are located near the blower motor.
p.s. you will only have 1 or the other.
My AC Unit is automatic Climate Control. I've taken out the glove box to inspect the area around the blower motor looking for a resistor. There is nothing there. There is just a two wire lead running to the bottom of the blower motor. If you know were the resistor is, please let me know. Additionally I tapped the bottom of the motor while the unit was on and it rumbled for a second then quit.
if you banged on it and it tried to work, then that blower motor is toast. if you still need the location of the speed controller, look for a connector with 5 wires coming out of it.
the wire colors are...
1-grey
2-green/violet
3-brown
4-yellow/blue
5-black/green
look to the immediate left of the blower motor connector, you should be able to see it.
