TomServo9
- February 19, 2002
- Minneapolis, MN
- 1992 Eddie Bauer 4dr 4x4
Hey guys-
I got a 92 Ex. About a week ago I was driving home from the cabin and got on the gas to pass someone and I thought I heard somthing and then thought I smelled antifreeze. I watched my temp very closely after this happened but it stayed in the normal range. As I got closer to my home and slowed down from interstate speeds the temp started to rise. I sped up to get some air into the engine as I was close to home. I got home and she was steaming. I popped the hood and noticed that the steam was comming from behind the engine so I crawled under the car and saw a steady stream of coolant comming from behind the engine down to the ground. I parked it and took the 02' for the week as I had a busy week. I gotta get this thing back on the road ASAP but I can't tell for the life of me where its leaking. It comes out fast enough that you would think its a hose but I don't believe there are any hoses that go directly behind the 4.0L. It seems to be running out from more on the drivers side back of the engine. I have the upper intake off and still can't tell where it is leaking from. I'm guessing either the lower intake or head gaskets. Anyone else have similar experiences. When I parked it it was running fine and no white smoke was comming from the exhaust. My oil level appears to be correct but I haven't drianed it yet to look for coolant. I started it again before taking off the intake and there was maybe a LITTLE white smoke, but it was cold out so it could have just been the cold air. It did smell a little rich however but this could be unrelated. Any ideas would be greatly appreciated. I don't really have the money to bring it in to be repaired. The transmission was just rebuilt
. Let me know what you guys think. Thanks a TON!!
