SmokeEater829
- February 26, 2013
- New Orleans LA
- 2013 Explorer
I just received my body bushing kit from James Duff. I knew it didn't come with the required hardware. And none of my factory hardware will be reusable. I'm planning on getting all new 1/2" bolts, locknuts, and washers to install with. My question is go I need to put a sleeve inside the bushings, or not. The factory hardware acts like a sleeve inside the bushing, so I'm thinking I need to do something similar to the factory setup. I'm guessing a piece of steel tubing with a 1/2" ID would allow the bolts to go thru and let the washers on each side hold everything together. Do I need this or not?
Thanks
Thanks
